[ICEM] ICEM Meshing Problem-2D Unstructured
Old   August 25, 2016, 17:13
Default ICEM Meshing Problem-2D Unstructured
Tariq Ahmed
Tariq Ahmed is on a distinguished road
I am doing a 2D simulation and created a 2D geometry. So I created a geometry as in the figure for a simple case where there is an U tube and hot water flows from one end (top) to the other(top). The tube goes through the rectangular domain(wall) where bulk water is present and exchanges heat with it.
I tried creating surface for the rectangular domain as one fluid and separated this surface from the pipe/tube curves and created another separate surface for the tube water. I am trying ICEM unstructured meshing since the real case has 16 bends of tubes and I am doing an initial simple case but for this simple case, I am not able to get a working mesh with boundary conditions in Fluent. I have specified all the boundary conditions but i get wall for all the parts i specified.
I have these following parts:
Adiabatic Thermal Wall (Rectangular Domain)
Fluid (Surface for the rectangular domain)
HEX Pipe Wall
Water Inlet
Water Outlet
Tube Fluid (Surface inside the tubes)
I also tried creating 2 bodies one for bulk water (FLUID) and another inside the tube (TUBE FLUID). But in Fluent, it doesn't recognize them as the above and gives the following
zones, wall_hex_pipe:003-shadow
wall_adiabatic_thermal_wall-shadow
wall_hex_pipe-shadow
wall_hex_pipe:004
wall_hex_pipe:003
wall_adiabatic_thermal_wall:002
wall_hex_pipe
int_hex_pipe
int_adiabatic_thermal_wallSlitting wall zone 16 into a coupled wall.
Error: 1nquire-adjacent-threads: not a face thread
Error Object: #f
Skipping zone fluid_outertubefluid (not referenced by grid).
Skipping zone tubefluid (not referenced by grid).
Skipping zone adiabatic_thermal_wall (not referenced by grid).
Skipping zone hex_pipe (not referenced by grid).
Skipping zone water_outlet (not referenced by grid).
Skipping zone int_outertubefluid (not referenced by grid).
Skipping zone int_fluid (not referenced by grid).
Skipping zone outertubefluid (not referenced by grid).
fluid
Skipping zone fluid (not referenced by grid).
fluid-11
It would be helpful if you can guide me through where the problem exists.
Tariq Ahmed is offline   Reply With Quote
[ICEM] ICEM CFD Interface meshing problem gamemakerh ANSYS Meshing & Geometry 1 December 12, 2016 04:41
[ICEM] ICEM 3d meshing problem Eng.Mahmoud abd elsalam ANSYS Meshing & Geometry 0 June 25, 2016 00:16
[ICEM] Meshing bifurcating pipe in ICEM problem Barak ANSYS Meshing & Geometry 2 March 14, 2015 08:12
[ICEM] Simple meshing problem in ICEM fkh ANSYS Meshing & Geometry 6 February 14, 2012 14:01
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
