[ANSYS Meshing] decreasing y+
Old   August 25, 2016, 04:16
Default decreasing y+
mehran mohammadi
mehran.mo is on a distinguished road
hi
i'm trying to meshing this geometry my mesh quality is good my y+ is about 60 but in section that multiphas is began is about 300 how can i Decrease it? my mesh size close to wall is 1mm and my vlosity in multiphase section is 2m/s , water come from nozzle and go out from diffuser and that above box is air.
thanks
mehran.mo is offline   Reply With Quote
Old   August 25, 2016, 08:33
Harry Eggo
harry94 is on a distinguished road
Run the simulation with what you have and graph out the y+ values you obtain after convergence. Then you can use the solver to target specific values of y + (I think it comes under the modify menu in the top toolbar) and run the simulation again for ~800 iterations. Check your result and keep repeating and checking what sort of values you are getting.
harry94 is offline   Reply With Quote
Old   August 30, 2016, 08:37
mehran mohammadi
thak u for replying
Water level decreasing - interFoam OEC OpenFOAM Running, Solving & CFD 0 April 16, 2015 10:28
Buoyant flow in a sealed rotating cavity - heat flux decreasing dpitz FLUENT 1 October 29, 2014 10:14
Avoid creation of bad cells while decreasing distance between parts? kg1913 ANSYS 0 September 5, 2014 07:05
Nusselt number is decreasing when using nanofluid using single phase phase approach kandoi Fluent Multiphase 1 March 5, 2014 14:30
Too large temperature decreasing above sound speed Roland R CFX 4 December 7, 2009 18:17
