[ANSYS Meshing] Bad stair stepping causing convergence problems and erroneous results
Old   August 22, 2016, 18:35
Default Bad stair stepping causing convergence problems and erroneous results
Chris
cfxturbomode123 is on a distinguished road
In my single fluid domain, I have a diffuser vane with a vortex generator on the bottom surface (hub). I am using tetrahedral unstructured meshing with inflation layers around the diffuser vane, shroud and hub so that I can capture separation.
The mesh for the vortex generator (two triangles) is refined using a sphere of influence but I am getting really bad stair stepping as you can see in the attachment. (ANSYS doesn't flag this)
inflation settings:
gap factor 0.5
maximum height over base: 0.1
growth rate type: geometric
Maximum angle 180 degrees
fillet ratio: 0.5
Smoothing iterations: 5
Even with layer compression the problem is still there with little to no improvement (see last attachment).
By the way, the time frame I have does not allow me to use ICEM meshing so please if an expert mesher on this forum has any detailed advice I really appreciate it.
File Type: jpg vortex generators with sphere of influence.jpg (188.0 KB, 40 views)
Last edited by cfxturbomode123; August 22, 2016 at 18:45. Reason: omission of info
cfxturbomode123 is offline   Reply With Quote
Old   August 26, 2016, 06:30
Paritosh Vasava
vasava will become famous soon enough
From pictures it seems that you are using 'Proximity' size function. Have you tried using different 'size functions'? If not, try with 'Fixed' or 'Off' options.
Also, try with 'First layer thickness' option and see how it goes.
vasava is offline   Reply With Quote
