[ANSYS Meshing] Overlapping contact region with cyclic dependencies
Old   August 17, 2016, 22:37
Default Overlapping contact region with cyclic dependencies
Minki Kim
mkkim400 is on a distinguished road
I am studying meniscus shape using ANSYS(17.1) Fluent, and having problem with the mesh. Meniscus shape consists of numerous facets, and Mesh in the whole system is generated without any error. However, mesh can not be exported and saved because of overlapping contact region in the geometry.
I used "Repair overlapping contact region" option to solve this problem, but ANSYS meshing program shows like: "Failed to repair Contact Region 1172. Contact Region 1172 has been suppressed." & "The mesh file exporter could not resolve cyclic dependencies in overlapping contact regions. Please try to Repair Overlapping Contact Regions."
Then, every contact region is suppressed, and mesh is not exported and saved.
Please let me know how to repair overlapping contact region, or to make better geometry.
File Type: jpg Overlapping contact region with cyclic dependencies.jpg (125.6 KB, 122 views)
mkkim400 is offline   Reply With Quote
Old   December 19, 2018, 09:02
liwenzhi
hameisi is on a distinguished road
hi,guys
Contact regions are said to be “overlapping” when the same entity is a member of more than one contact region or when multiple contact regions share the same geometry. ANSYS Fluent does not support overlapping contact regions.
you need to find the cyclic contact region ,and then suspress it
hameisi is offline   Reply With Quote
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
Why Menter's SST model low-Re issue has not been seriously investigated? vkrastev OpenFOAM 58 January 8, 2018 16:20
Overlapping geometry in Contact Regions ajejebrazo89 FLUENT 0 December 16, 2015 13:43
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
