[DesignModeler] Always failing for surface from edges
Old   August 17, 2016, 19:32
Default Always failing for surface from edges
E.T.
drercardio is on a distinguished road
I tried a simple vessel like tube for flow simulation and try to make surfaces from the edges in design modeler but always give error What can be the problem, I tried repair tool but no progress. Please I need kind supports.
drercardio is offline   Reply With Quote
Old   August 17, 2016, 19:57
Kapi is on a distinguished road
more details and pics necessary to understand your problem!
Kapi is offline   Reply With Quote
Old   August 19, 2016, 16:35
E.T.
I try to make a surface to cap both sides of the tube but always failed in Design modeler. I also tried the repair for hard edges. But I don't understand why it doesn't work.
Old   August 19, 2016, 16:39
Angry
E.T.
I added some other pictures
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
