[ANSYS Meshing] Stairstep mesh
Old   August 17, 2016, 15:43
Default Stairstep mesh
david glynn
davd4696@gmail.com is on a distinguished road
Hi Folks,
I am currently trying to model a 3D vertical axis turbine with straight blades using Ansys 14.5 and Fluent, I have booleaned out my blades and shaft from the rotating domain all went to plan.
however when I try to mesh in Ansys mesher I get the warning "Inflation created stairstep mesh at some locations" when I create a section and examine the mesh I can the stairstep is created towards the trailing edge (see attached)
I have searched this forum and it is suggested to change the angle to 180 degrees from the default of 140 degrees, I tried this and it didn't work.
I'd appreciate it if anyone could help me with this problem.
Regards,
Dave
davd4696@gmail.com is offline   Reply With Quote
Old   September 28, 2017, 03:03
Yoo Rin
Yoo Rin is on a distinguished road
Hi David.
I got the same problem as you. Have you solve the meshing problem "stairstep"?
Yoo Rin is offline   Reply With Quote
fluent, inflation layer, meshing 3d, stairstep, turbine blade
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? RPjack ANSYS Meshing & Geometry 2 August 27, 2015 10:33
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 14:40
