[ANSYS Meshing] Mixed Order Meshing in ANSYS Meshing |
August 9, 2016, 06:56 |
Onur Özcan
Rep Power: 12 |
Hi all,
I am working on temperature distribution of some equipments that have been used in glass packaging. There are 3 zone. One of them solid zone and remaining are fluid zones. First, solid one has been meshed (patch-independent).Then environmental fluid zone has been meshed by patch comforming with together inflated this method by inflation.Last one fluid zone has been meshed by sweeping with together inflated this method by inflation. and error has been occured ''Mixed order meshing is not available when meshing per body. To allow mixed order meshing, clear the generated data on the relevant parts and generate the mesh directly from those parts or from the Mesh folder. I have tried above explanation ! No hope has been shown :S Anyone who help me will be appreciated! |
August 1, 2020, 06:48 |
Rep Power: 6 |
Hello
I am struggling with the same error. How did you resolve it? Thanks |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
Ansys airfoil meshing problem | Salah87 | ANSYS | 0 | August 13, 2015 02:49 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
2d meshing in ansys meshing | syler3321 | ANSYS Meshing & Geometry | 10 | November 1, 2012 20:42 |
Strange ANSYS Meshing 13.0 Problem | brunob | ANSYS Meshing & Geometry | 3 | June 21, 2011 20:03 |
