[ICEM] the error for smoothing process
Old   July 28, 2016, 05:53
Post the error for smoothing process
松本貴大
takahiro is on a distinguished road
Hello, Everyone.
I make mesh, and such an error occurs when I am trying to smoothing process (smooth hexahedral mesh orthogonal).
Would you tell me that is considered to be the cause of what.
an internal error has occurred :
can't read "test_smooth(fams_attr, 0, NACA64A210_1)": no such element in array while executing
"set val $test_smooth(fams_attr,$i,$part)"… …
Usage environment is ICEM CFD 16.0 Academic.
takahiro is offline   Reply With Quote
2dimesion, error, icem, smoothing, wing
The fl process could not be started because of UDF majid_kamyab Fluent UDF and Scheme Programming 6 December 15, 2015 09:42
Problem running in parralel Val OpenFOAM Running, Solving & CFD 1 June 12, 2014 03:47
error 262144 and unexpected disconnect when run on 2 nodes Emily1412 SU2 Installation 1 April 10, 2014 18:08
How to setup a simple OpenFOAM cluster? TommiPLaiho OpenFOAM Installation 3 October 27, 2013 16:15
dxFoamExec orphan process bigphil OpenFOAM Post-Processing 0 March 19, 2009 12:08
