July 13, 2016, 07:25 |
Uncovered faces
Cris
Hello, I know this issue has been discussed in previous threads, but none of the solutions I have found solves my problem.
I am meshing the geometry that you can see in the picture. I want to mesh the air that surrounds the cones, so the cones itself are empty. I am only considering their surface. I have tried making the block in 3 different ways and it doesnt make any difference. They all look like the one in the picture. When I try Edit Mesh-Check Mesh-Check/fix each, and I allow the program to fix the uncovered faces, it creates a new part that involves the whole geometry and I dont know what to do with it when I import it to Fluent. Please, if you think of any common mistake I have probably made or a possible solution, tell me. I would be so grateful, I have spent the last week trying to solve this problem. duda.png duda 2.png duda 3.png duda 4.png duda 5.png |
July 15, 2016, 04:43 |
Cris
I have tried, but it doesn't let me because of the "uncovered faces" problem.
July 15, 2016, 11:54 |
Rep Power: 11 |
I think if you determine the name of that new part will help you more (when you select "fix" at the left down corner of it you can enter the name of new part) and if you already have done that inspect the part individually, it must be just a shell that wants to get its boundary condition!
I have another problem with uncovered face! I have done what simon said in http://www.cfd-online.com/Forums/ans...h-writing.html but still I get critical errors in fluent during reading mesh file! |
July 15, 2016, 17:43 |
faces, icem 14.0, uncovered |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 10:23 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 11:58 |
