[ANSYS Meshing] Script Connection Friction
Old   July 7, 2016, 05:38
Arrow Script Connection Friction
arpeedesign is on a distinguished road
Hello all,
I'm scripting an epicycloid gear in 2D. I am able to create the required mesh and I'd like to set a frictional connection between the pins and the gear by using script. What are the functions or the syntaxes for that? Should I make named selections for each pin? What is the easiest solution for it?
Can anybody help me in these problems?
Best regards!
Arpad
arpeedesign is offline   Reply With Quote
Old   July 7, 2016, 19:51
Kapi is on a distinguished road
Hi Arpad,
Are you using design modeler?
You have to do named selection for each pin in order to call them for connections.
named selection of bodies can be done like this:
var pin1 = ag.fm.Body(ag.fm.BodyCount-1);
pin1.Name = "Apin1"
show your code what you have done manually and what you want to achieve by script both in pics
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   July 8, 2016, 07:17
Hey Kapi!
Thanks for the help. I didn't know this syntax. It's good for change the name of the geometry item in the part list. But I'd like to set Named Selections, as I mentioned in this thread. (NamedSel_DM_.PNG and NamedSel_DM_tree.PNG) I use them to make the mesh size and I have no idea how to creat them in the Design Modeler by script.
I attached the pics what I want to do with the connections. All of the connections are named like this: Contact Region x. So I thought I'd use this name to change bonded to frictional; friction coefficient to 0,07 and the interface treatment Adjust to Touch. OR if I can make the NamedSlections for every part and edge, then I could use them for set the contact and the target, after I changed the scoping method.
Thank you for helping me!
Best regards!
Arpad
//Accesing Mesh Control Properties
var Mesh_Mod = DS.Tree.FirstActiveBranch.MeshControlGroup;
DS.Script.SelectItems(""+Mesh_Mod.ID);
//Insert the edge sizing for Epicycloid
DS.Script.doInsertMeshSize(1)
ListView.ActivateItem("Scoping Method");
ListView.ItemValue = "Named Selection" ;
ListView.ActivateItem("Named Selection");
ListView.ItemValue = "Epicycloid" ;
ListView.ActivateItem("Type");
ListView.ItemValue = "Element Size" ;
ListView.ActivateItem("Element Size");
ListView.ItemValue = "0.1"
ListView.SelectedItem.IsChecked="false"
//Insert the infaltion for Epicycloid
DS.Script.doInsertInflation(1)
ListView.ItemValue = "Epi_srf" ;
ListView.ActivateItem("Boundary Scoping Method");
ListView.ItemValue = "Named Selections" ;
ListView.ActivateItem("Boundary");
ListView.ActivateItem("Inflation Option");
ListView.ItemValue = "First Layer Thickness" ;
ListView.ActivateItem("First Layer Height");
ListView.ItemValue = "0,1"
ListView.ActivateItem("Maximum Layers");
ListView.ItemValue = "6"
ListView.ActivateItem("Growth Rate");
ListView.ItemValue = "1,15"
//Insert the edge sizing for circle of the gear
ListView.ItemValue = "Epi_crc" ;
ListView.ItemValue = "1"
//Insert the face sizing for the gear
//Insert the mesh method
DS.Script.doInsertMeshElementShape(1)
ListView.ItemValue = "Gear_Body" ;
ListView.ActivateItem("Method");
ListView.ItemValue = "Triangles" ;
//Insert the edge sizing for external circle of the excenter
ListView.ItemValue = "Ex_ext_crc" ;
//Insert the face sizing for the excenter
ListView.ItemValue = "Ex_srf" ;
//Insert the face sizing for the pin
ListView.ItemValue = "Pin_srf" ;
ListView.ItemValue = "0,5"
//Insert the mappesface for the pin
DS.Script.doInsertMeshMappedMeshing(1)
//Generate Mesh
DS.Script.doModelPreviewMeshFromToolbar(1)
//Accesing the boundary conditions properties
var Env = DS.Tree.FirstActiveBranch.Environment;
DS.Script.SelectItems(""+Env.ID);
//Creating Moment at the gear circle
DS.Script.doInsertEnvironmentFreeMoment(1)
ListView.ActivateItem("Magnitude");
ListView.ItemValue = "248000" ;
//Insert the fixed support on pin
DS.Script.doInsertEnvironmentFixedDisplacement(1)
ListView.ItemValue = "Pin_int_crc" ;
//Insert the fixed support on the excenter
ListView.ItemValue = "Ex_int_crc" ;
DS.Script.doInsertEnvironmentFrictionlessDisplacement(1)
Old   July 10, 2016, 23:02
those are automatic connection made my mesh
personally I dont like those connections untill I am 100% sure about them.
I prefer to make named selection of with side of connection and make interface.I use something like this:
/create array for partID and TopoId for each body
var partID = new Array ();
var TopoId = new Array ();
//Named section or interface #1
for (var i= 1; i<=count; i++) {
    partID[i] = ds.SelectionManager.SelectedPartID(i);
    TopoId[i] = ds.SelectionManager.SelectedEntityTopoID(i);
SM.Clear();//clear any existing selection
	for (var i= 1; i<=1; i++) {
    var part = ds.SelectionManager.PartMgr.PartById(partID[i]);
    var brep = part.BRep;
    var body = brep.Cell(TopoId[i]);
    var faces = body.faces;//get total faces of each body
    //loop the faces to get the face partID and topoID
    var faceCount = faces.Count;
	//SM.Clear(); //clear any existing selection
    for (j= 7;j<=faceCount-2; j++) {
		face = faces(j);
		var aTopoId = face.Id;
		SM.ForceSelect(partID[i], aTopoId); //force select face based on part id and topo id
	name = "Interf_" + NS + " 2";
	ds.Script.addNamedSelection(false, name); //create named selection
	ds.Script.updateNamedSelectionsToolbar();
You can create NS similarly for face, edge or body.
Hope this is what you are after.
Cheers
KAPI
Old   April 11, 2019, 09:17
shufangwang
user12345678 is on a distinguished road
Originally Posted by arpeedesign View Post
Hey Kapi!
Best regards!
Arpad
//Generate Mesh
hi Arpad,
Do you know how to change to the frictional connection by script now?
I met the same problem.
Could you please give me a hint?
Thanks!
user12345678 is offline   Reply With Quote
connection, friction, mesh2d, script
[Workbench] Run ICEM Script in Workbench Script MIZOR ANSYS Meshing & Geometry 9 April 4, 2018 08:45
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 08:24
Radiation interface hinca CFX 15 January 26, 2014 18:11
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 11:45
CentFOAM Python Script Installation: Error socon009 OpenFOAM Installation 2 May 26, 2012 10:36
