June 27, 2016, 12:46 |
#21 |
Rep Power: 10 |
Using the information found in this post, I added inflation to the sweep method. However, it turned out like this:
I would like to achieve the inflation seen here: I've attempted to achieve it using edge sizing, but that isn't quite what I am after. |
July 5, 2016, 13:03 |
#22 |
Rep Power: 10 |
If anyone knows how to properly apply inflation to a sweep method such as the one depicted in my previous post, I would be very grateful if you would share your knowledge.
July 13, 2016, 13:38 |
#23 |
Rep Power: 10 |
After speaking with a graduate student, I've come to the conclusion that because my flow rate is such a low velocity I do not need to apply inflation.
However, I am still interested in learning how to apply inflation to this scenario so that I may use the knowledge in the future so I would appreciate any answer to my previous post. |
January 29, 2018, 07:57 |
#24 | |
Junior
Many thanks. |
cylinder, inflation, mesh, multizone |
hex mesh of cylinder with embedded cuboids | joanwa | Mesh Generation & Pre-Processing | 0 | February 1, 2016 11:22 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 10, 2008 00:02 |
