[DesignModeler] A parametric parabolic geometry |
Rep Power: 13 ![]() |
Hello
I want to perform a parametric study that involves flow through a pipe with a parabolic occluder. I have created a sketch with the parabola and a circle, shown on the image (left), using a spline defined by 3 points. That is the only way I could find. However when I change the location of the points defining the spline, by modifying the parameters controlling dimensions, the shape of the curve changes back into a spline (image right), as if there were additional points on it. Does anyone have a clue how to draw a parabola in DesignModeler or how to overcome this shape changing problem? I know that if I go to Modify -> Spline Edit and refit the spline it works fine, but I would like to do it automatically from the Workbench level. Any ideas how to do it? Thank you Krzysztof |
design modeler, parabola, spline |
[DesignModeler] Fill tool - grouping the faces of a complicated geometry? | HeikkiT | ANSYS Meshing & Geometry | 8 | July 20, 2016 07:37 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 13:49 |
Geometry for Confined Circular Jet | Greatness | FLUENT | 0 | October 1, 2013 05:04 |
Export geometry file from ansys mechanical | browns6 | Structural Mechanics | 0 | August 27, 2013 16:19 |
2D geometry to 3D geometry | Sgonzalezg | ANSYS Meshing & Geometry | 11 | April 8, 2011 11:02 |
