June 23, 2016, 02:59 |
perforated circular cylindrical pipe
Ankit Gautam
Rep Power: 10 |
What would be the best strategy for blocking the geometry attached in ICEM CFD? The geometry is a perforated cylinder with axial inlet and exit through radial holes and axial top. The geometry is surrounded with the pool of same fluid that is entering the cylinder. 60 degree axial symmetry exists in the geometry.
Thanks in advance. |
June 23, 2016, 20:03 |
Ghazlani M. Ali
Rep Power: 29 |
Depending on the difficulty of your simulation you can for tri or hexa. the 60 degrees sector is a good starting point. Now go block it !!
Share geometry if you want assistance |
June 24, 2016, 02:28 |
Ankit Gautam
Rep Power: 10 |
Thanks for quick reply, Ali.
I have tried several strategies but the problem arises when I create part separately for the blocks from fluid domain that contains the cylindrical geometry inside wall (solid) region. As soon as I do that the association changes and my mesh distorts. I have already posted the association problem in http://www.cfd-online.com/Forums/ans...g-problem.html that I faced and you were the one who replied (Thanks for that too). Attaching the .step file of my geometry. Thanks! computational domain small.zip |
June 24, 2016, 10:40 |
Ghazlani M. Ali
Rep Power: 29 |
I managed to start the blocking and block on hole. it's up to you to finish it. by blocking the other holes, and adjusting the vertices, association face to surfaces if needed...
June 24, 2016, 11:47 |
Ankit Gautam
Rep Power: 10 |
Thanks a lot, Ali and sijal.
blocking strategy, icem cfd 14.5, structured mesh. |
Modeling of underdrain Perforated pipe | Tanjina | FLUENT | 1 | April 16, 2015 16:30 |
Zone Creation on an induced cylindrical pipe | Taiwo_Oni | Tecplot | 0 | August 24, 2014 20:05 |
Two-phase flow in a circular horizontal pipe | DmitryS | Fluent Multiphase | 0 | May 17, 2014 17:22 |
flow in perforated pipe distributor | pertupd | ANSYS | 0 | August 12, 2009 09:36 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
