[ANSYS Meshing] Interface node number and memory allocation problem
Old   June 22, 2016, 02:22
Default Interface node number and memory allocation problem
Jinwhan Ryuk
Whitebear is on a distinguished road
Is there anyone who know memory allocation for interface node number? There are many long and thin pipe in the cylindrical tank. Hot gas flow in the pipe and water flows between tubes in the tank oppositely. So there are many interface between tube surface and tank. Is there any tip for setting memory allocation in CFX due to interface nodes number? I thought 128gigabyte memory was enough for any problem but I was wrong.
Whitebear is offline   Reply With Quote
Old   June 22, 2016, 05:08
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
problem is not memory, but the aspect ratio at interface. size change between elements on both sides of interface should be less than 10
Far is offline   Reply With Quote
Old   June 22, 2016, 05:41
Jinwhan Ryuk
Thank you very much Far. I'll check it and try again. Where do you and can you check 'the aspect ratio at interface?' I can't find it. Mesh statics shows only overall aspect ratio only.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
