[DesignModeler] Rotating a surface on a specific axis |
June 18, 2016, 09:08 |
SAA
Rep Power: 11 |
Hi all,
Ive got a surface from solidworks imported to designModeler its an airfoil surface which i would be subtracting from flow domain using boolean but i would like to rotate this surface about the axis passing through the point the two splines used to make the airfoil surface are joined and be parallel to the z axis (the sketch i have is 2d so z axis is perpendicular to it ). So is there a way to do it ?? I know about body transform >rotate but how do i make that axis ive failed miserably trying to make it . I know it might be very easy for you but I work mostly on solidworks and designmodeler is a bit new to me . |
February 16, 2017, 02:15 |
[solved]
GS
Rep Power: 10 |
In the menu bar.
Create ---> Body Transformation ----> Rotate |
August 11, 2021, 04:23 |
Md. Faysal Hossain
I am facing the same problem. I just want to rotate the object with respect to Z-axis. But I can't select Z-axis in the Axis Selection option. How can I Do that?
August 11, 2021, 09:44 |
Stuart
Rep Power: 26 |
I assume you have Rotate -> Axis Definition = Selection and you cannot select an axis to populate the Axis Selection = None box.
Have you changed to Axis Definition = Components, then use the default X Component = Y Component = 0 and Z Component = 1 to rotate about the z-axis only and set the required angle. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
Modeling a rotating vertical axis stream turbine | VIMeerkat | FLUENT | 0 | February 11, 2013 14:03 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
rotating domain in rotating domain, different axis | Robert Stringer | CFX | 3 | December 4, 2006 08:04 |
