[ANSYS Meshing] Poor mesh quality using inflation layers with sharp-angled tapered pin geometry
Old   June 14, 2016, 14:41
Default Poor mesh quality using inflation layers with sharp-angled tapered pin geometry
Julien
jhco is on a distinguished road
I'm running heat exchange simulations on pin fin arrays using FLUENT with varying tapered pin geometries. These tests are all between Reynold's number 0 to ~20k, corresponding to velocity inlets of 0-14 m/s.
I've gotten good data out of most of the pin geometries I've tested, where the mesh looks like below (top view)
http://i.imgur.com/8U6r9db.png
However, some of the geometries have much higher aspect ratios and sharper angles, such as the fin array below. I have struggled to create a mesh with acceptable minimum quality (~1e-3) while maintaining inflation layers within the pins.
http://i.imgur.com/2REGT3U.png
http://i.imgur.com/Jg2Uhrv.png
I've exhausted all of my ideas for this. For example, the following image is a mesh with inflation control applied separately to the fluid and solid geometries. Whether I try to size by first-layer thickness or smooth transition, the interior cells at the tail end are too large, resulting in highly skewed inflation layer cells.
I'm a relative novice at meshing for CFD (my background is mechanical)-- what would be the recommended strategy for mesh control or settings?
http://i.imgur.com/9stmK3p.png
These images are also attached to the post. Thank you for any advice you can offer.
jhco is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[ANSYS Meshing] Inflation Layers disappearing - airfoil krekel13 ANSYS Meshing & Geometry 0 January 24, 2015 14:55
[ICEM] Creating prisms layers for a geometry with sharp angles Eirik ANSYS Meshing & Geometry 0 January 13, 2015 10:07
[ANSYS Meshing] Assembly inflation mesh failing for different geometry orientation PedFr0 ANSYS Meshing & Geometry 0 June 12, 2014 09:21
Fluent diverges when using inflation layers ziggo FLUENT 4 August 9, 2013 13:11
