[DesignModeler] Extrude Cut through Cross-section
Old   June 12, 2016, 22:39
Default Extrude Cut through Cross-section
Harrison Vince
hvince95 is on a distinguished road
Is there any way to cut material from a cross section which has been assigned to a line section? I have tried Extrude Cutting a surface sketch however in the model view the cut is not visible.
Thanks,
Harry.
hvince95 is offline   Reply With Quote
cross section, cut, extrude
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 06:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 17:14
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 11:45
[Gmsh] Cannot get the right mesh from gmsh JinBiao OpenFOAM Meshing & Mesh Conversion 2 August 31, 2010 05:51
