June 10, 2016, 13:54 |
Building geometry meshing problem
Yatharth Vaishnani
I am having a problem in creating the Cartesian volumetric mesh using ICEM. My geometry consists of a building geometry within a control volume. The wall thickness is 2 mm and the control volume is 0.94*0.9*0.4 m3. I am attaching the screenshots of the geometry and the mesh. As I am creating the mesh using default parameters, the wall is generated only on the top of the building and on the control volume. (In the screenshot, surfaces of the control volume are not selected.) As per my observation, I think there may be problems in 2 steps: 1. I have created the body of building geometry using surface selection, and the body point is showing on the top part. (That may be the reason of mesh generation in Top part.) 2. As the minimum dimension of the wall thickness is only 2 mm, there may be a problem in creating the mesh using default parameters. I have worked with 2D meshing before, but I am new to 3D in ICEM. Please help me. Thanks in advance! |
June 12, 2016, 06:33 |
Ghazlani M. Ali
Rep Power: 29 |
You should get good result if you block this geometry. Invest some time in learning how to block. For a geometry like this it will take you like one morning. care to share your geometry ? ?
Airfoil simulation - Divergence of the results - Mesh or geometry problem ? | Pol.P | FLUENT | 9 | March 7, 2022 17:21 |
[ICEM] Problem with meshing 2D geometry | Nicolastheterminator | ANSYS Meshing & Geometry | 1 | December 18, 2013 21:39 |
[ANSYS Meshing] Meshing problem in a constricted geometry | kozden | ANSYS Meshing & Geometry | 0 | December 18, 2013 03:39 |
[Workbench] Problem to select facing when updating geometry | vbernard | ANSYS Meshing & Geometry | 1 | October 28, 2013 09:18 |
Problem meshing turb. blade tip clearance geometry | Balu | FLUENT | 0 | June 7, 2008 21:10 |
