[ANSYS Meshing] cut cell with inflation
Old   June 2, 2016, 14:40
Smile cut cell with inflation
Fan E
Fan0182 is on a distinguished road
newbie to ansys mesh
I want to use inflation to refine the boundary layer with cutcell method to mesh interior part, but Mesh warning me
'Program controlled inflation with assembly meshing requires virtual bodies or fluid bodies. The program controlled inflation will be ignored.'
what should I do?
plus I've read from this thread [URL="http://www.cfd-online.com/Forums/ansys-meshing/97162-hex-dominant-method-local-inflation.html"]
that
"In that case, if you are in Workbench, I suggest Cutcel. It will give you what you want and works nicely with inflation..."
so i think cutcell+inflation works, but how?
Fan0182 is offline   Reply With Quote
Old   October 22, 2016, 11:04
nurjs
nurjs is on a distinguished road
Hi Fan
I realy dont know and i forced same problem
i need good quality and very small skewness
i find like this mesh by using tetrahedron +inflation , but it very fine mesh 7900621 node and take a lot of time.
i using cut cell mesh it gives very good quality but not work with inflation
if you find any answer for your qusation . please send me any advice.
my geometry complex and i work on different types of mesh but yet now not found a ccurate mesh.
nurjs is offline   Reply With Quote
cutcell, inflation layer, mesh 3d
Cartesian Cut cell method - how to treat body corner? shirazbj Main CFD Forum 2 November 6, 2017 00:34
Cut Cell Meshing Jenisha_Naidoo ANSYS Meshing & Geometry 6 April 9, 2017 01:37
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
[snappyHexMesh] snappyhexmesh cell splitted ununiform..2D case sharonyue OpenFOAM Meshing & Mesh Conversion 1 April 23, 2013 00:34
Help for cut cell scheme for moving problems Wei Main CFD Forum 0 August 2, 2006 10:32
