[ICEM] Holes in wind turbine blade mesh
Old   May 24, 2016, 05:57
Default Holes in wind turbine blade mesh
Maciek Górski
goral04 is on a distinguished road
I would like to create good mesh for wind turbine rotor. Im using student license so, i can not generate more than 512k nodes. On images im presenting my geometry, mesh settings and what i have achieved.
I can not fix it to get continuous mesh on the traling edge of blade.
goral04 is offline   Reply With Quote
Old   May 25, 2016, 05:16
Sebastian Engel
bluebase will become famous soon enough
Hi Maciek,
this is no answer to your problem.
Have you thought of doing only a "third"-slice of your domain? You could later add three parts to your solver to have the full domain again. That way you could increase the 500k limit to virtual 1.5M and have more room to play with the mesh settings.
with regards,
Sebastian
bluebase is offline   Reply With Quote
Old   May 25, 2016, 05:19
Maciek Górski
Yes, i have thought about it, but still this holes appears in the mesh, and i can not get rid of them.
And i also have another problem, that when i set mesh parameter for traling edge to be small, i supose shell mesh is not generated because there is no mesh on blade surface, only volume mesh around the blade.
Wind Turbine blade in 120° wedge - boundary conditions Fcamp OpenFOAM Running, Solving & CFD 1 December 2, 2019 07:47
Virtual Blade Model (VBM) for wind turbine. teymourj FLUENT 27 July 4, 2018 08:03
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Problem in conducting CFD of analysis of wind turbine blade atulpat CFX 16 August 17, 2013 05:09
Sliding Mesh and Wind Turbine FJSJ FLUENT 1 June 27, 2013 02:32
