[ANSYS Meshing] 2D inflation layer contains triangles
Old   May 23, 2016, 22:20
Default 2D inflation layer contains triangles
Kevin Jones
jones007 is on a distinguished road
I'm trying to build a mesh around a thin airfoil using an inflation layer and curvature control. Under curvature control I cannot seem to input curvature normal angle values of less that 0.1 degree. If I use this, then there seems to be a limit for the initial wall spacing height in the inflation layer. If I use a relatively large first height, then I get a well behaved inflation region - all quads visible in the 2D plane. If I make the first layer a little thinner, than most of the inflation layer turns to thin triangular cells - basically each quad cut in half diagonally. I thought perhaps this was a graphic defect, but the solution on this grid will not converge. Solutions on the grid with a thicker first layer converge nicely, but the Yplus value is too large.
With experimentation, I found that there was some form of coupling between the curvature normal angle and the first inflation layer height. I don't think it is a direct coupling, but the curvature normal angle sets up the circumferential spacing around the foil, and this seems to be coupled to the acceptable first cell height.
Does anyone know how to set a smaller curvature normal angle or perhaps another way to handle this? Thanks.
jones007 is offline   Reply With Quote
Old   March 31, 2019, 15:19
sheaker's Avatar
Oskar
sheaker is on a distinguished road
Dear All,
I am facing the same issue. Any solution?
Best regards,
Oskar
sheaker is offline   Reply With Quote
Old   April 6, 2020, 10:18
Exclamation Inflation quad elements become triangular at trailing edge of airfoil
sy yao is on a distinguished road
I faced the similar problem. I applied same settings for both global and local inflation. I tried varying some parameters such as number of divisions along the airfoil and total thickness of inflation, the problem persists. I'm using ANSYS 19.2.
I hope I can find the solution asap, this is for my fyp (it's kind of urgent).
Thanks in advance!
sy yao is offline   Reply With Quote
Old   April 6, 2020, 10:54
Gert-Jan
Gert-Jan will become famous soon enough
It is best to extend the tail with a thin surface through your fluid domain and then inflate both sides. As a result the inflation won't degrade at the end of the tail but will continue away from the tail. Extend the thin surface to the outlet.
Then in the CFD setup, use your thin surface as an interface through which the fluid can penetrate.
Gert-Jan is offline   Reply With Quote
Old   May 1, 2020, 11:27
Thank you for your reply, Gert-Jan.
Do you mean split the domain at the trailing edge of the airfoil like this?
Old   May 1, 2020, 11:36
Gert-Jan
Yes. This is what I meant.
Old   May 4, 2020, 03:14
Thanks, Gert-Jan.
I have solved the inflation meshing problem.
My mesh will roughly be something as shown in the picture attached.
The blue region is my rotating domain while the grey one is static. Will the big difference between the size of elements has negative impact on the cfd results later?
Old   May 4, 2020, 04:16
Gert-Jan
Impossible to say. I don't know what question you are trying to answer using CFD.
Now I would say: give it a try and see what it brings.
Old   May 4, 2020, 09:42
Okay, I will give it a try.
Thanks again, Gert-Jan.
Total Thickness of Inflation Layer prikeyma CFX 5 August 28, 2020 04:22
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 06:53
Prismatic boundary layer KateEisenhower enGrid 5 September 15, 2015 08:48
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
