Inflation at ANSYS Meshing
Old   May 23, 2016, 08:26
Default Inflation at ANSYS Meshing
Prasenjit Sanyal
Prasenjit Sanyal is on a distinguished road
Generally we use inflation around 4 faces of a building to give a smooth flow. But if there is a inner portion of building then can we also use inflation there?? Why not we provide inflation at top of a building ??
Prasenjit Sanyal is offline   Reply With Quote
Old   May 24, 2016, 02:16
Steffen595 is on a distinguished road
geuess you have to work out, where it is important.
In a building? The boundary layer is pretty thin, is it necessary?
Steffen595 is offline   Reply With Quote
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem dalecooper ANSYS Meshing & Geometry 0 July 19, 2013 08:04
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 01:43
