[ICEM] Create different blocks for different bodies
Old   May 22, 2016, 06:20
Default Create different blocks for different bodies
Alam Swift is on a distinguished road
The upper region of this model is air, the lower region is water and the object in the air is what I want to drop into water. So I need to mesh the three parts separately as if they are different bodies. But now I can only create one block. I hope that I can create different blocks (At least two, one for the object, and one for the air and water). Could you please tell me how to mesh in ICEM?
Alam Swift is offline   Reply With Quote
Old   May 23, 2016, 04:45
Paurnamie Samarakone
Nat Sam is on a distinguished road
Hi
I'm far from being an ICEM pro but...
1) You could first start by creating one blocking that covers your whole geometry.
2) Then generate an O-grid 'cause you have a cylinder...
3) Then you can slice it in half so that in the upper half you have the violet part and in the lower part you have the green one.
4) Finally another O-grid in the upper half since you have another cylinder inside...
Hope this helps. Good luck !
Nat Sam is offline   Reply With Quote
Old   May 23, 2016, 05:17
Sebastian Engel
bluebase will become famous soon enough
Hi Alam,
i think you have two options. It depends on whether you need the mesh on interface surfaces.
If you don't need the interfaces you can just create an additional part and move the respective blocks to that part. (The blocking tab needs to be selected, then, in the add to part options, moving blocks will be available).
The second option is to create subtopologies. Usually there is only a root topology. Check it in the blocking tree. The respective option is found in the context menu.
That way you can create blockings for different regions also with matching interface mesh. I then have to use convert to unstructured for my solvers. I don't know if this works with other "final" meshes, too. Assuming you also need an 'unstructured' mesh for the icem mesh converter, then, you need to select the first subblocking and convert it. Do it sequently with the other two topologies, but remember to use Merge and not Replace for the 2nd, 3rd,.. topology.
That way you obtain a mesh with two matching interface meshes between two blockings.
with regards,
Sebastian
bluebase is offline   Reply With Quote
Old   May 23, 2016, 05:21
Yes Sebastian you're right.
I suggested a second O-grid inside the upper half assuming Alam Swift needs to mesh that inner cylinder too...
And assuming he needed a structured grid. That's what I'm using... Your optionr are probably best suited.
icem
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
[ICEM] Two boxes connected by a cylinder, blocks merge where I don't want them to merge. Polarbear ANSYS Meshing & Geometry 4 April 30, 2014 16:21
How to create 2 separate Surface Bodies? Matlab69 FLUENT 5 April 22, 2012 15:53
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
