[ANSYS Meshing] Mesh of concentric cylinders with hole |
May 17, 2016, 10:05 |
Rep Power: 10 |
Hi there!
My geometry consists of two concentric cylinders, with the outer one having a thick slot on the top (like a moneybox) at a certain distance from the sides. Can you help me obtaining a good mesh? I just have to make a linear static mechanical analysis (a simple bending test) so it will be a stress concentration near the slot, and I want the mesh to be good there. I tried at first with an automatic mesh, but the problem is the inner cylinder has no defects; this means the elements are very different in the contact points (outer surface of the inner cylinder and inner surface of the outer one). Thank you for your help! |
May 19, 2016, 02:11 |
Rep Power: 14 |
make a sweep. (mesh->insert mesh method -> sweep) Less cells and faster (especially helpful in academic with cells limit).
If you split the culindric surface at certain angles like a pie. If you do the inner and outer tube same angles, the cells will line up. Then split the pipe solid where the slot is, do automatic mesher just there, with curvature and proximity. Then wou will get a fine mesh around the slot, where its critical |
May 19, 2016, 06:57 |
#3 | ||
Rep Power: 10 |
Than you very much for your help! |
May 19, 2016, 07:15 |
Rep Power: 14 |
no, dont solit the solids. Split the surfaces, in your CAD. Or if Design modeller can do that, do it there. I am not using DM, CAD is more convenient.
The mesh cells of both walls dont have to match, pretty impossible. But if you make a sweep with angles and the same number od separations they become quite close. The slot will have finer mesh and this has to be so, because there happens the most. Id you have CAD wit FEA, can do some qick simulation there. |
May 25, 2016, 09:13 |
Rep Power: 10 |
Using the "Proximity and curvature" command my mesh has too many elements, I have to reduce them drastically. Is there a way to do it just for one solid and not for all of them? I choose the automatic method near the slot, and the sweep in the other two solids (on the left and on the right of the slot). But the "proximity and curvature" is selected on the general settings of the meshing.
May 25, 2016, 11:00 |
Rep Power: 10 |
What I'm noticing is that using "Proximity and Curvature" I obtain a mesh which doesn't change if I add the sweep control, or an automatic method, or whatever. What am I missing?
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
Problem with geometry - concentric cylinders | Rhoddwen | OpenFOAM Running, Solving & CFD | 0 | December 15, 2014 10:22 |
[ICEM] Hole is created while decreasing mesh size | cbaraj | ANSYS Meshing & Geometry | 1 | October 29, 2013 13:32 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
