[ICEM] Error when generating a surface resolution
Old   May 12, 2016, 11:00
Default Error when generating a surface resolution
Paurnamie Samarakone
Nat Sam is on a distinguished road
Hello everyone
I'm trying to draw a cylinder with 2 circles and on curve joining those 2 circles. To create the surface of the cylinder, I'm trying to use "Surface of Resolution" funtion in "Create / Modify Surface". I've done it before in a similar case and it worked. Bu this time, I get this error message :
Error : Surface of Resolution failed
Error : creating rev : {Unable to create rev surface} {Degenerate xAxis in IcCgArc}
Could you help me ?
Best Regards
Nat
Nat Sam is offline   Reply With Quote
Old   May 13, 2016, 05:29
I solved my issue. I was selecting the wrong axis points ^^'
Old   May 13, 2016, 08:15
Default check mesh
Radwanma
Radwanma is on a distinguished road
HI All,
I have faced a problem in my mesh as in the following pictures , how can I solve this problem cause I cannot get correct Cm values, please ?
Radwanma is offline   Reply With Quote
Old   May 13, 2016, 10:44
Hi
I'm far from being an ICEM pro but that sort of thing happens to me when I haven't correctly projected my faces...
Old   May 13, 2016, 13:16
Default Hi
Radwanma
Hi Sam,
Thanks for your reply, how can I solve this problem , please, thanks
Old   May 17, 2016, 04:16
Hi
Sorry for this late reply. This Monday was a bank holiday here so...
Anyway, to associate faces :
Blocking --> Associate --> Assiciate Face to Surface
You could also cancel previous associations. Sometimes, eventhough you associate faces, your vertices and edges don't get associated. It's a small problem in ICEM sometimes. So you need to do that manually.
In your tree, in Blocking, do a right click on Faces and select Show association. This can help you.
That is... If your problem is due to an incorrect association.
Good luck
Old   May 17, 2016, 07:36
Radwanma
HI Sam,
I appreciate you reply. I forgot to remember you that my mesh is unstructured type, is your solution could use to solve the problem?
Regards,
Old   May 17, 2016, 07:41
Radwanma
This picture for my mesh
Old   May 17, 2016, 08:35
Hi
I'm afraid I have never used unstructured mesh on ICEM. However, face association is must be the same for any kind of mesh right ? I mean your mesh depends on each "part" of your object so... You start meshing the surface right ? So I believe you have to associate anyway.
I suggest you post a new thread with a more appropriate title... Explain what you have done so far. Other people might also help you ^^
Good luck
cylinder, icem, surface resolution
[GAMBIT] Problems with surface vectors orientation when generating mesh with GAMBIT solalito ANSYS Meshing & Geometry 0 April 27, 2015 10:57
Error message when generating the surface mesh for a NACA66MOD airfoil blebon enGrid 0 November 4, 2014 11:30
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 19:48
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
