[ANSYS Meshing] Meshing a Simple Pipe With Different Diameters
Old   May 9, 2016, 05:14
Default Meshing a Simple Pipe With Different Diameters
Adnan Reza
Adnann is on a distinguished road
Hello folks .
Currently I want to simulate a Fluid-Structure Interaction (FSI) analysis. I want to simulate a flow that goes through an orifice, and how it affects the pipe and Flow-Induced Vibration of the pipe.
However, I'm having trouble meshing the pipe and orifice. I used the default meshing, but the results look very terrible, with very high Skewness. I understand that this is a case of pipe with different diameters. Can anyone help me? Attached is the design of my geometry
Adnann is offline   Reply With Quote
Old   May 9, 2016, 19:32
Kapi is on a distinguished road
use help section in Ansys to understand how meshing is done.
Search for similar threads on CFDonline to get your answers.
Kapi is offline   Reply With Quote
Old   May 16, 2016, 04:38
Adnan Reza
Ah thank you for the help
In any case I have just finished one System Coupling analysis. However, after 100 coupling steps, the solid part of the analysis is converged but not the fluid.
How do I increase the number of coupling steps? I could not seem to find it
[ANSYS Meshing] pipe with different diameters (steady and sudden expansion) Raiz ANSYS Meshing & Geometry 0 October 12, 2015 07:18
[Other] modelling & meshing of submerged pipe simonsg OpenFOAM Meshing & Mesh Conversion 0 October 24, 2014 11:31
icoFoam simple pipe wont write pressure basilwatson OpenFOAM Running, Solving & CFD 2 May 15, 2011 12:04
some weird results about a simple pipe flow: Ning FLUENT 2 March 11, 2007 14:23
meshing at a pipe intersection cyn FLUENT 0 December 20, 2006 03:16
