May 5, 2016, 18:44 |
Ansys meshing problem
behzad Ghasemi
Rep Power: 13 |
Hi dear forumers,
I want to mesh a cubic cavity with a thin region in it. I defined nodes and edges then parted the cub in 8 sections to define surface and perform a mapped mesh. I did not use sketch method because it's not produce desired mapped mesh around thin region. problem arises when i import mesh in fluent and it assumes that section lines are wall. how can i solve this problem? Geometry pictures are attached. Thanks in advance 2.PNG Capture1.PNG |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 11:49 |
Mesh difference between 14.5 version and 15.0 version in ansys meshing | sunxihui | ANSYS Meshing & Geometry | 0 | May 6, 2014 05:22 |
[ANSYS Meshing] Problem with ANSYS Meshing - how to refine? | pyroknife | ANSYS Meshing & Geometry | 2 | August 22, 2013 14:30 |
[ANSYS Meshing] Meshing Problem in worbench | elina | ANSYS Meshing & Geometry | 0 | March 31, 2013 09:53 |
[Other] Ansys meshing airfoil and / or compressor blades | baw192 | ANSYS Meshing & Geometry | 8 | September 23, 2011 01:43 |
