[ANSYS Meshing] Suggested workflow for cavity meshing
Old   April 26, 2016, 15:48
Default Suggested workflow for cavity meshing
the-sted is on a distinguished road
Hi All,
I am trying to create a simulation for an electronics enclosure that is vented in air and cooled via natural convection.
I am using solidworks to create the geometry and ANSYS meshing to create the mesh to go into fluent.
My question is what are your recommendations for workflow to make sure that the model comes into fluent with the right contact regions and interfaces for heat transfer?
I am having a hard time visualizing if the right surfaces are being chosen by ANSYS meshing and fluent when creating these interfaces. I create a volume in solidworks by making a large box(the air) and then creating a cavity from all the parts in the assembly. In solidworks I have removed much of the complexity of the parts and bonded several parts of the same material together, before ANSYS sees them. Still, gaps are overlooked and determined as contact surfaces in ANSYS.
Is it best to define all these contact surfaces in solidworks as named selections?
Another question, do I need to have only one target surface for one contact surface?
Thanks for the help.
the-sted is offline   Reply With Quote
[ANSYS Meshing] only automatic meshing works, kazra ANSYS Meshing & Geometry 2 February 23, 2017 12:38
Meshing Process sidharth9426 STAR-CCM+ 4 September 15, 2015 04:31
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
[ANSYS Meshing] Meshing strategy for External Flows Hybrid ANSYS Meshing & Geometry 0 January 24, 2012 15:27
is free meshing or mapped meshing is best for flow problems shanu Main CFD Forum 0 February 18, 2010 12:58
