April 26, 2016, 08:30 |
no valid body found error
Seyfi Girgin
Rep Power: 11 |
Hi all
I hava a 2d sketch in solidworks 2015 and saved it as part1.sldprt I run the workbench 2015 then from geometry i imported this file but when i generate it i came up with "no valid body" error.I selected the import geometry as 2d also from tools-options-geometry import but nothing changed. I am using licensed products for both from university network. Please help |
July 31, 2016, 18:50 |
vlg
Rep Power: 18 |
[QUOTE=seyfigirgin;596760]
i came up with "no valid body" error. /QUOTE] Dear seyfigirgin! Check this post: http://www.cfd-online.com/Forums/ans...tml#post228887 1) Geometry - Advanced - Analysis Tyoe - 2D 2) your geometry should be in XY plane. If you want to use axisymmetric featre of FLUENT, the geomtery should lay in +Y semiplane. X should be the axis of rotational symmetry. |
ansys workbench 15, error, solidworks. |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 07:11 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
