[ANSYS Meshing] problem with mesh quality
Old   April 18, 2016, 11:25
Default problem with mesh quality
yaseen
yaseen wsu is on a distinguished road
hello everyone
I simulate free surface flow my geometry complex, so I divided into eight parts. sweap method used in ANSYS meshing for swepable bodies and tetrahedron and multizone method for others, but the problem is skewness which is 0.966 (max), I tried by sizing but I can not reduced it. Who can suggest me to improve my mesh quality.
thanks
yaseen wsu is offline   Reply With Quote
Old   April 18, 2016, 19:44
Kapi is on a distinguished road
sizing is the best way to reduce your skewness and improve quality.
Please post your mesh where you are getting high skewness.
You can use behavior "HARD" in sizing
Kapi is offline   Reply With Quote
Old   April 19, 2016, 08:16
yaseen
thanks for your reply
my geometry is complex, some parts finer than others, what due you mean by(HARD) in sizing?
the follow is my meshing model, thanks for your suggestion, max. value of skewness in the tetrahedron part
http://www.cfd-online.com/Forums/att...1&d=1461063279
http://www.cfd-online.com/Forums/att...1&d=1461063297
http://www.cfd-online.com/Forums/att...1&d=1461063316
https://drive.google.com/open?id=0B3...GtsazRUbUVMYkk
Old   April 28, 2016, 09:22
Paritosh Vasava
vasava will become famous soon enough
When you use sizing in Ansys Meshing, the 'behavior' can be 'Hard' or 'Soft'. By selecting soft, you are allowing Ansys meshing to over-ride the sizing, because it thinks that it can give you better mesh by NOT obeying the sizing you input.
Do post pictures of the mesh and model.
vasava is offline   Reply With Quote
Old   April 29, 2016, 03:16
use lower size elements where you need fine mesh and make sure you use behavior "Hard"
I strongly suggest to refer to Help section, read it thru
if you dont get your answer then search for similar threads on this forum
and even after this if you dont get your answer then only post a question!!
I am sure you will get help from help section.
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[ICEM] Prism Quality mesh problem bharath ANSYS Meshing & Geometry 5 April 14, 2014 10:22
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
