[ICEM] error while importing mesh to FLUENT from ICEM |
April 13, 2016, 08:41 |
Anuj
Rep Power: 10 |
I created mesh in ICEM by using blocking. then MESH is converted in to Unstructured mesh and imported to FLUENT.
During Mesh Check, I found : left-handed faces detected on zone 20: 65694 right-handed, 84 left-handed. left-handed faces detected on zone 23: 3574 right-handed, 36 left-handed Info: Used modified centroid in 52 cell(s) to prevent left-handed faces. It is recommended that you try to fix the left-handed faces WARNING: The mesh contains high aspect ratio quadrilateral, hexahedral, or polyhedral cells. The default algorithm used to compute the wall distance required by the turbulence models might produce wrong results in these cells. Please inspect the wall distance by displaying the contours of the 'Cell Wall Distance' at the boundaries. If you observe any irregularities we recommend the use of an alternative algorithm to correct the wall distance. Please select /solve/initialize/repair-wall-distance using the text user interface to switch to the alternative algorithm. How can I solve it. Why are these warnings coming during Mesh check. Can anyone help me . Thank in advance |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[ICEM] The ICEM Guide for CFX Users | JuPa | ANSYS Meshing & Geometry | 11 | September 4, 2017 10:43 |
Trouble with importing intricate block-structured mesh from ICEM to Fluent | highhopes | FLUENT | 0 | February 22, 2015 15:02 |
[ICEM] ICEM 2D Mesh to Fluent 14.5 | Lmecano | ANSYS Meshing & Geometry | 1 | February 18, 2015 05:56 |
[ICEM] 2D Mesh from ICEM to ANSYS FLUENT | TomM | ANSYS Meshing & Geometry | 1 | May 8, 2013 15:07 |
