[ANSYS Meshing] Mapped face - sweep problem
Old   April 13, 2016, 08:32
Default Mapped face - sweep problem
Tebo
tebo13 is on a distinguished road
I want to share my mesh problem with you in order to find a solution. In fact, I want to mesh a gap of 20 microns with a uniform mesh. So I divided the part into several areas (the gap area and the inlet/outlet region). The first figure shows that the multi-zone and the mapped face method allows to have the desired mesh Figure 1. The problem happens when I change the géomtrie of the part. Using the same techniques I can not have the three divisions in the gap (figure 2).
Figure1:
Figure2:
Have you any solution. Thank you!
tebo13 is offline   Reply With Quote
Old   April 13, 2016, 08:34
Default Mesh gap problem (sweep, mapped face, multizone)
Tebo
Figure1: https://www.flickr.com/photos/433353.../shares/50W8f6
Figure2:
https://www.flickr.com/photos/433353.../shares/77R2TR
mesh sweep gap multizone
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 19:25
[ANSYS Meshing] Mapped Face meshing Thermal_engg ANSYS Meshing & Geometry 4 June 5, 2013 06:37
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[Commercial meshers] Face ordering problem for nonrectangular cyclic boundary conditions cfdmarkus OpenFOAM Meshing & Mesh Conversion 3 August 17, 2011 16:07
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
