[ICEM] 3D geometry to 2D
Old   March 29, 2016, 12:17
Default 3D geometry to 2D
m
medo20051989 is on a distinguished road
If i have a symmetric 3d geometry ( Impulse turbine blade, same shape extruded in z-direction ) so can i use ICEM geometry tools ( like delete curve and surface ) to convert the geometry to 2d ( the front surface of the blade) cause it's difficult for me to draw the model again in design modeler.
medo20051989 is offline   Reply With Quote
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 03:52
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 14:02
How to scale and translate the grid of particle data and STL geometry Saidul Tecplot 1 January 11, 2015 22:15
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 04:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 14:49
