[ANSYS Meshing] How can I mesh a 3-D sieve column?
Old   March 23, 2016, 11:11
Default How can I mesh a 3-D sieve column?
Ali Reza
alip67 is on a distinguished road
Hi
I want to mesh a perforated sieve column but I cant use structured mesh,and when I use unstructured mesh(tetrahedral-TGrid) its worst element skewness becomes 0.99,what can I do for reducing the skewness?
I wanted to mesh the middle part of the column( part that has plates). First, I meshed the*perfurations( I selected each*perfuration one by one and meshed its upper and bottom circle as an edge) then I tried to mesh the middle hole like the*perfurations, then I meshed the surface of each sieve(meshed the faces) after that, I splitted the outer surface of middle rod with two vertices in order to create edges. I needed these edges to use exponent meshing scheme so that *I could have finer meshes near the sieves. then I meshed the outer face of middle rod, I then I tried to mesh the whole volume, but I couldn't succeed. what should I do? where was I wrong? [ATTACH][ATTACH]3.JPG[/ATTACH][/ATTACH]
alip67 is offline   Reply With Quote
column, mesh 3d, sieve tray
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
