[ANSYS Meshing] Mesh error
Old   March 19, 2016, 18:38
Default Mesh error
Yoshi Toshi
wiggles8x0 is on a distinguished road
Should be a simple fix but honestly I can't figure out whats causing this errors to show up:
"A patch-conforming tetrahedral mesh failed because of duplicated nodes in boundary mesh."
"A mesh could not be generated using the current meshing options and settings"
So I am doing a very simple simulation of adding a nozzle at the end of a flow. I have individually meshed each component and no errors come up. After that, I have also meshed each individual component with an enclosure and no errors. Next, I combined the parts and meshed with no enclosure, still no errors. But now when I try and add an enclosure around the combined parts, that error shows up and I can't understand why.
If it were a boundary issue between the individual parts, that error would have showed up when I meshed the two without the enclosure but it never did. So I don't get how the enclosure is causing errors on a boundary mesh. If only the error also said where the boundary mesh error were occurring it would have been easier to understand what's causing the problem.
Anyone have idea on why its occurring?
Ps. Just to clarify the drawing, the nozzle is added after the end of the pipe.
wiggles8x0 is offline   Reply With Quote
Old   March 19, 2016, 20:29
Yoshi Toshi
I tried again by filling up the nozzle and this time the meshing didn't stop for 10 mins. So the only thing I can assume from this is that there really is some problem where the pipe and nozzle meet but can't seem to understand why.
One possible reason could be that there is a gap between the pipe and nozzle but that doesn't make much sense since they were designed to be flush with each other in solidworks.
Old   March 19, 2016, 20:39
Yoshi Toshi
I made the nozzle part again and this time when using the revolve feature, I didn't do a thin revolve. Now meshing works just fine.
It's interesting that the thin-revolve feature didn't create a flat surface (that's the only logical solution I can come up with why I was getting errors before since there was probably a really really small gap between the pipe and nozzle. The enclosure was probably trying to figure out how to fill this up but couldn't and then gave the incorrect error). Weird solidworks mechanic!
Old   March 29, 2016, 04:42
Paritosh Vasava
vasava will become famous soon enough
Can you post picture of the outline ribbon on the left side (the one that contains all the setup info.). Also make all the domains transparent and post a picture especially the part where the pipe and nozzle are meeting.
vasava is offline   Reply With Quote
Old   March 29, 2016, 11:19
Yoshi Toshi
Thank you for trying to help! I resolved the issue myself
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 07:45
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
