[ICEM] Meshing failure for solidworks imported geometry
Old   March 8, 2016, 12:47
Unhappy Meshing failure for solidworks imported geometry
Zeeshan Shabbir
zeeshanshabbir is on a distinguished road
I have modeled a wind turbine blade in solidworks. After importing it to design modeler and creating fluid domain, when i try to mesh the geometry,it fails. I have tried both sldprt and IGS formats. Geometry does not even mesh with automatic meshing.
zeeshanshabbir is offline   Reply With Quote
Old   March 15, 2016, 05:34
Nader Khattabi
bboynido is on a distinguished road
maybe you should freeze the blade geometry before creating your domain, then split the blade from the domain.
try to use Parasolid format(x_t) instead of those formats maybe it works
bboynido is offline   Reply With Quote
Old   March 16, 2016, 07:52
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
You should bring good quality geometry.
Far is offline   Reply With Quote
Old   March 16, 2016, 15:40
Zeeshan Shabbir
Thank you all for your replies. Enabling body cleaning and suppressing all bodies except solid bodies before generating imported geometry worked for me.
design modeller, failed meshing, icem 15.0, mesh 3d
Issue With Meshing Imported Geometry zoeysj ANSYS 1 February 7, 2016 00:12
[GAMBIT] spray dryer geometry meshing gambit deepak11091 ANSYS Meshing & Geometry 1 October 29, 2015 03:07
[ICEM] Meshing on a Complicated Geometry tav98f ANSYS Meshing & Geometry 2 August 17, 2011 12:15
[DesignModeler] Parameterize the imported geometry swiss_zhang ANSYS Meshing & Geometry 0 June 28, 2011 03:54
IGES/IGS format geometry file for icem meshing littlelz Main CFD Forum 0 May 27, 2008 19:24
