[ANSYS Meshing] How to change the type of "zero wall thickness" internal baffle to "Internal" |
March 7, 2016, 12:08 |
Prasanna Welahettige
Rep Power: 10 |
How to change the type of "zero wall thickness" internal baffle to Internal. Because it is not considering at Fluent simulation. Further explaining, I have to make stationary mixing wall inside the fluid domain. I want to make those mixing plates as zero thickness to reduce the number of elements generation. I tried with using this plates as boundary condition name "wall", then it is not considering in fluent simulation. Some reference is telling in Gambit, change the type of planes to "Internal". But I'm working with Ansys Meshing. Any of u know how to do it in Ansys Meshing or any other alternative method for this? Thanks and best regards, Prasanna. |
wallHeatFlux utility for an incompressible case | Mr.Jingles | OpenFOAM Post-Processing | 67 | April 6, 2023 03:25 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
singularity? | mihaipruna | OpenFOAM Running, Solving & CFD | 5 | April 24, 2012 17:18 |
