[ICEM] Blocking topology for bluff body corners |
March 5, 2016, 03:12 |
Stuart
Rep Power: 26 |
Can anyone assist with blocking around the corners of this model? Also on making a Y-block on the surface? The images show the two locations. I've changed the the vertex locations at the corners to improve the elment quality but cannot see the ideal surface block arrangement. Attached are the ICEM files. I've not yet made on O-grid and I have only assigned a global element size. The CFD domain is small as this is a testcase on making the blocking. Thanks in advance. |
6dof model - floating body | flinde | FLUENT | 13 | March 6, 2021 14:32 |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 07:26 |
[ICEM] Wing Body Tutorial - Improved blocking | Far | ANSYS Meshing & Geometry | 2 | August 3, 2013 20:16 |
[Need some advise] Am I doing right?? Simulating a rotational mixer | setasena | STAR-CCM+ | 4 | March 10, 2013 10:32 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
