[ICEM] How To Improve Pre Mesh Quality In O grid Based Double Pipe Cylinder
Old   February 25, 2016, 07:54
Default How To Improve Pre Mesh Quality In O grid Based Double Pipe Cylinder
Shomaz ul Haq
Shomaz ul Haq is on a distinguished road
Send a message via Skype™ to Shomaz ul Haq
Dear all,
Hi. Hope all are well. I am facing a problem of bad quality for Criterion Angle. I am using O grid. How can I improve quality? I am attaching jpeg. Would be grateful. Thanks.
Shomaz ul Haq is offline   Reply With Quote
Old   February 26, 2016, 05:13
Attique Javaid
attiquejavaid08 is on a distinguished road
Originally Posted by Shomaz ul Haq View Post
Dear all,
attach some clear picture of cross-sectional view and blocking edges
attiquejavaid08 is offline   Reply With Quote
Old   February 26, 2016, 12:07
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I guess O-grid has not been generated successfully !
Far is offline   Reply With Quote
Old   February 27, 2016, 02:00
Shomaz ul Haq
Thank you attiquejavaid08. I have attached image of cross section with blocking edges. Please help me in improving quality. Thank you Far. Far why do you think O grid is not successful? And if something is wrong with the O grid how can I improve it? Would be grateful.
File Type: jpg Cross Section Mesh With Blocking Edges.jpg (97.1 KB, 72 views)
Old   February 27, 2016, 06:03
Shomaz ul Haq
I have managed to improve the quality for Criterion angle by including another O grid inside.
Old   January 15, 2018, 06:58
Federico
eeLio is on a distinguished road
Dear Shomaz,
I am facing the same problem,
Did you manage to solve your issue? Although you improve your quality with another o-grid you still have "bad elements" in terms of "angle" around the four corners?
I was thinking that maybe there is a way to change the type of mesh of the o-grid (but still mostly hexa elements)...
Best
eelio
eeLio is offline   Reply With Quote
Old   January 15, 2018, 07:38
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Originally Posted by eeLio View Post
Dear Shomaz,
Best
eelio
In the small circle inside when you do an O grid you associate and use spline to make the edges in the shape of a circle. But for the O grid that goes inside you keep it as a square without linear or spline splits and thus avoiding making it circular. that will improve the corners.
shereez234 is offline   Reply With Quote
[TGrid] How can I improve mesh quality in TGrid? hasanifte ANSYS Meshing & Geometry 0 April 1, 2015 21:27
[ICEM] Improve Quality of Tetra Mesh geod ANSYS Meshing & Geometry 8 December 12, 2014 10:14
[ICEM] mesh in-dependency and mesh quality control sujay ANSYS Meshing & Geometry 0 February 20, 2013 03:06
[ICEM] how to improve mesh quality around sharp edge? foolboy007 ANSYS Meshing & Geometry 1 January 23, 2013 12:57
Improve smoothness & quality of structured grid quarkz Main CFD Forum 2 March 10, 2007 16:26
