[ICEM] Cylinder mesh - boundary condition parts problem
Old   February 15, 2016, 10:06
Default Cylinder mesh - boundary condition parts problem
Fabio Malizia
Fabio88 is on a distinguished road
I am creating the mesh around a 2D cylinder using ICEM.
I created the parts (top, inlet, bottom, outlet, cylinder) and assigned them the correct curve.
I make the blocking, premeshing, then I convert to unstructured mesh. When I assign the boundary conditions, I saw that when I fix the boundary condition to the top part, all the far field (top, inlet, bottom) highlights. Indeed when I import the mesh in fluent I just have top, cylinder and outlet bcs.
Do you have any tips to how to solve this issue?
I tried to delete the top part and create a new top, but results do not change or I get the followign error:
Mesh has uncovered edges. ANSYS Fluent needs a complete boundary (lines in 2D) or it will give a variety of errors and not read in the mesh! If this was 2D Hexa, perhaps your edges are not associated with perimeter curves.
I really appreciate if anyone can give me some tips to how to solve the problem!
Thanks a lot!!!
Fabio
Fabio88 is offline   Reply With Quote
converting error, cylinder mesh, icem
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 12:14
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
