[ANSYS Meshing] Cutcell meshing
Old   February 8, 2016, 23:01
Default Cutcell meshing
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hello everyone,
I am trying to mesh a Assembly by using cutcells in ansys meshing by using fixed value. Proximity and proximity and curvature Assembly meshing methods are failing due to insufficient memory. With fixed value I m getting good mesh but now I want to increase the number of elements in a small gap, other methods are not working.
Please suggest me any tutorials are any methods to solve this problem.
Regards,
Sunil
sunilpatil is offline   Reply With Quote
Old   February 10, 2016, 20:02
hwet is on a distinguished road
Cutcell is highly automated so you wont have much control over it. If the mesh is failing due to memory issues try turning of proximity and increase the curvature span angle.
If you want more control over the mesh probably dont use cutcell
hwet is offline   Reply With Quote
Interface Creation For Sliding Mesh Using Cutcell Meshing Sot FLUENT 0 January 9, 2016 06:34
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
[Other] Cutcell meshing skewness RSaid ANSYS Meshing & Geometry 1 December 16, 2014 13:09
[ANSYS Meshing] Cutcell meshing quality issue shiva102 ANSYS Meshing & Geometry 1 April 29, 2014 06:17
[ANSYS Meshing] Periodic issues in cutcell meshing jsm ANSYS Meshing & Geometry 7 March 8, 2012 22:00
