[ICEM] Copy Bunching to selected and parallel? |
February 4, 2016, 10:55 |
Andrew Norfolk
Rep Power: 10 |
Hi everyone.
I'm reasonably new to ICEM and i'm trying to mesh a 58 fin heat sink. I'm trying to copy an edge sizing from one edge to 56 other identical but non-parallel edges. This can be done easily through the "selected edges" option under match edges and copy bunching. The problem is that these sizing are not automatically copied to the parallel edges of those 56 edges. On the original sizing I only had to select copy to parallel but this is not carried through to the edges via the copy bunching. Does anybody know of a workaround or do I need to manually select those 56 edges and all their parallels when I copy the bunching (there is a lot of them as I've had to split the block numerous times ) Thanks for your help. |
February 8, 2016, 10:02 |
Andrew Norfolk
Rep Power: 10 |
I'm not having much luck getting a reply so I've attached a picture that explains my problem.
Basically, I have created an edge parameter which is automatically copied to all the parallel edges... great. Now I want to copy that edge parameter to another set of edges INCLUDING the parallel edges of this new set of edges. I have tried doing this with the match edges>copy bunching option however this does not copy to the new parallel edges automatically. Is the only way to achieve my desired goal to manually copy to every parallel edge? Any hints appreciated. |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 06:31 |
[snappyHexMesh] shm in parallel with simple decomposition | mihaipruna | OpenFOAM Meshing & Mesh Conversion | 6 | July 16, 2015 05:55 |
interDyMFoam in parallel | idefix | OpenFOAM Running, Solving & CFD | 0 | May 21, 2013 03:34 |
No times selected after successful parallel run | Myoldmopar | OpenFOAM Post-Processing | 4 | January 25, 2012 11:31 |
[ICEM] Match spacing of nodes | shib | ANSYS Meshing & Geometry | 5 | April 27, 2010 17:29 |
