[DesignModeler] Face Split for Intefaces / Contacts
Old   January 29, 2016, 09:54
Default Face Split for Intefaces / Contacts
Marcel Jay
marcel_jay is on a distinguished road
Hello everybody,
I have problem with a quite complex model which has many contacts between bodies. For a CFX Simulation it is problematic, if one face is in contact with different media (e.g. multiple Solid and Fluid). Therefore you need to split up faces to make the simulation work.
So my question is, if it is possible to automatically split up faces that are in contact. Meshing recognizes the contacts but doesn't split. A manual split up process in DM would take very long.
Has anyone encountered a similiar problem?
Cheers
Marcel
marcel_jay is offline   Reply With Quote
Old   January 31, 2016, 17:56
Kapi is on a distinguished road
Hi Marcel,
Once you have created your geometry and you have bodies listed in DM under "Part, Body" on left panel. Click on the body to see the details panel below. In the details panel you will see "Share Topology Method", Change from dropdown "Automatic" to "Imprints" and you should be able to solve your problem. (pic attached)
Kapi
Kapi is offline   Reply With Quote
Old   February 4, 2016, 09:25
Marcel Jay
Hello Kapi,
thanks a lot for your help. This feature is great. The only problme i have left, is that the automatic connections in Ansys Meshing don't seem to get it all. The Automode selects faces that are thanks to Share Topology, not anymore in contact with the other body. Therefore I have to edit almost every of my 67 Connections by hand.
Have you encountered this problem? I set the tolerance value to 1e-8.
Cheers,
Marcel
Old   March 3, 2016, 21:16
select all or make it a part and then change it to imprints.
Old   March 5, 2016, 07:18
Onur Özcan
oozcan is on a distinguished road
Originally Posted by marcel_jay View Post
Hello everybody,
Cheers
Marcel
you dont need to split anything up. as Kapi said that you need to click share topo in DesingModeller and ''imprints'' button will be you ok.But dont forget it make your project ''Form New Part'' in DesignModeller''
Kidn Regards,
oozcan is offline   Reply With Quote
Old   March 7, 2016, 10:50
Marcel Jay
What I was referring to is what I think, an error in the auto detection of the connections. Having the imprint option activated, there should be the same amount of sizes on each body, right?
Well, in my attachment you see that a face was detected to be in contact, but it actually is not.
Old   March 7, 2016, 11:30
Onur Özcan
as far as I know you mean blue color is covered in differant face and it doesnt provide contact region mutual.
things I have working on always are same sizing on both part.if you enable to cut it as a symmetrical,try it but i never have tried on different bodies to contact
Old   March 8, 2016, 09:08
Marcel Jay
The blue color covers two adjacent faces, only one of those faces (the hidden one) is in contact with the other body. Can you explain this behaviour?
cfx, contacts, face split, interface
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
