[ICEM] Asking for help! How to make biased mesh at multiple locations in swept meshing
Old   January 27, 2016, 23:48
Unhappy Asking for help! How to make biased mesh at multiple locations in swept meshing
Harry Zhang
harryosu is on a distinguished road
Guys!!! Please help on this problem. You can look at the attached picture. What I am meshing is a long semi-circular pipe with zigzag pattern. I have used ANSYS Meshing to generate the mesh by sweeping the entire body along the "zigzag" path. However, what I want to improve in the mesh is that the grid needs to be finer at the zigzag bend spots than any other locations, like the one I show in the attached figure, and I have no idea how to do that in ANSYS Meshing. It only provides a sort of "global" biased sweeping. It cannot allow you to make biased fine mesh at multiple locations. I know probably ICEM CFD can do that job, but I am a newbie and only familiar with ANSYS Meshing environment. I did begin learning ICEM CFD to solve the problem but this geometry is extremely long in one dimension, and with so many zigzag bend sections, I don't know how to create mesh in ICEM. Please help! Please give some advice on this problem! And also in general how to do the sweeping in ICEM?
harryosu is offline   Reply With Quote
Old   January 29, 2016, 03:41
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hello Harry,
What you need to use in AM is the sizing feature. rmb> insert > sizing. Select the side edges of your model and apply. Under the sizing definition, change the type to number of divisions and then select the bias type behavior you need.
Easy fix, have fun
Gweher is offline   Reply With Quote
Old   January 29, 2016, 03:48
Harry Zhang
Thanks Gwenael!
However, as you can see it has multiple bends (actually in this specific model 60 bends). I just wonder if there is an easy way, something like copy and paste, to do that side edge sizing at all of these bends, otherwise it will be a humongous labor work required... which is definitely not fun
Still thanks for the help!
Harry
Old   January 29, 2016, 03:56
Gweher's Avatar
Gwenael H.
Well no there is no other way around if you want to have the mesh you want. And honestly this will take you max 15min, which is nothing basically. I finished to work on a model with ICEM a week ago where I had to associate more than 11'000 edges and curves, you're already lucky that AM takes care of a lot of work and never forget that pre-processing requires nearly 70% of the total time that you need to solve a problem.
[ICEM] ICEM meshing - Tips from forum - Collection shereez234 ANSYS Meshing & Geometry 0 June 16, 2015 10:47
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 03:36
