[ANSYS Meshing] Help in How to Recreate Mesh
Old   January 26, 2016, 16:55
Default Help in How to Recreate Mesh
Jordan
irishguy is on a distinguished road
Hello, I'm failing to remember how to create a mesh more like the mesh shown in the picture below on the left rather than the mesh on the right. I did this a long time ago and I'd like to cut down on the number of cells far away from the elbow and increase the cells inside the narrow passage.
I want to basically recreate the mesh seen on the left photo where the cells are much smaller in the elbow and much larger far away from the narrow passage.
It should be noted that I use ANSYS Workbench 14.5 and I use the meshing program within Workbench, not in fluent.
Thanks!!
irishguy is offline   Reply With Quote
Old   January 27, 2016, 12:05
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
You should start looking at the basic meshing function that are available in AM or ICEM. There are a tons of examples related to your problem, you can use a local refinement near the area of interest.
In AM -> RMB > insert > sizing > sphere of influence.
Gweher is offline   Reply With Quote
mesh 2d, mesh and grid, meshing a 2d
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? RPjack ANSYS Meshing & Geometry 2 August 27, 2015 10:33
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
