[ANSYS Meshing] Issue with airfoil geometry to meshing
Old   January 5, 2016, 16:03
Exclamation Issue with airfoil geometry to meshing
Adrian Costantino
Acostant is on a distinguished road
I am trying to desinge a rear wing for my schools FSAE team and I am having trouble with meshing an air foil. In the pictures below the wall is not in the correct location on the meshing module but displays correctly in the geometry module. I believe that this is also causing problems with convergence as the other set of airfoils I modeled for the front wing did not have this issue and the solution converged. thank you for the help.
Acostant is offline   Reply With Quote
Old   January 6, 2016, 23:48
hwet is on a distinguished road
I think in the geometry module you are displacing a continuous edge and in the meshing you have just selected a part of this edge and named it instead. you can selected all edges and name them as a singular wall by holding control
hwet is offline   Reply With Quote
Old   January 7, 2016, 00:50
Adrian Costantino
I have already selected the entire body and named it. It will not let me select the proper wall on the meshing.
Old   January 7, 2016, 05:31
DId you make the geometry in design modeler? If not,use the geometry correction options, get rid of hard edges etc
Old   January 7, 2016, 14:17
Adrian Costantino
I imported the cat using SolidWorks into the design manager Ivan have a boolean created using a wall for a two dimensional analysis. This issue a curse typically with the bottom or middle wing. This doesn't always happen but occurs 90% of the time.
Old   January 29, 2016, 00:31
DrDevice is on a distinguished road
I've had the same problem in ANSYS 16, but it worked for me in 15 fine. If you can, try that.
DrDevice is offline   Reply With Quote
airfoil 2d, formula student, fsae, meshing 2d
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 17:18
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
Reg difficulties in meshing the geometry...Urgent arunraj ANSYS Meshing & Geometry 0 August 27, 2011 00:25
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
