[Workbench] Rotated cylinder doesn't slice box |
January 4, 2016, 13:04 |
Paja
Rep Power: 13 |
Hi all,
I am using Design modeler and I need to create box with cylinder inside with specific angle. I created a box (create-primitives-box) and cylinder (extruded from sketch and added by operation slice material), this works perfect - the material is sliced into two parts (box and cylinder). But once I use the rotation (body transformation - rotate), cylinder is rotated but the material is not sliced respectivelly it is sliced as i didnt use the rotation. Does anyone know how I shoud do this? Thanks! Paja |
January 6, 2016, 00:34 |
Rep Power: 14 |
post some pics!
January 6, 2016, 08:38 |
Paja
Rep Power: 13 |
There are pictures. I really don't understand why the box is not sliced by rotated cylinder.
January 13, 2016, 10:42 |
Rep Power: 13 |
What do you want to achieve? Slice is used to divide the geometry into smaller parts.
If you want a cylinder inside your body you need to use the 'revolve' tool instead. |
box, cylinder, rotate, slice |
[OpenFOAM] Paraview slice type - cylinder? | acocic | ParaView | 39 | September 28, 2024 12:42 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 17:16 |
Forces Acting on a Rotating Cylinder (Moving Mesh) | dreamchaser | CFX | 5 | April 25, 2015 07:01 |
Creating thin slice out of a cylinder | lakhi | FLUENT | 0 | March 4, 2014 02:09 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 04:56 |
