[GAMBIT] SketchUp Pro to Fluent or Gambit CFD
Old   February 6, 2009, 15:28
Default SketchUp Pro to Fluent or Gambit CFD
Steve Johnson
Looking for advise as to simplest method to translate SketchUp 3D model into format Fluent or Gambit CFD software can import. According to Gambit the following file formats can be imported: FIDAP, GAMBIT, I-DEAS UNV, ANSYS, NASTRAN, PATRAN, PLOT3D FORMATTED,FLUENT4, FLUENT5, TGRID, STL, HYPERMESH. My SketchUp Pro 3D software can export into the following file formats: 3D DWG or DXF, 3D FBX, 3D XSI, 3D OBJ, 3D VRML, 3D 3DS, STL. The common denominator between these two software programs appears to be and STL file but I am having some difficulty importing the STL into Gambit. Has anyone tried this transfer before with any success? Any advise would help. Steve
Old   March 2, 2009, 16:27
Default re: SketchUp Pro to Fluent or Gambit CFD
MM
How are you exporting it? Does Fluent only accept models that are triangulated in form?
Old   April 6, 2010, 19:21
Smile SketchUp to Fluent
Tim
heachinbar is on a distinguished road
I have successfully used SketchUp to get my models into Gambit using SolidWorks to transfer the SketchUp .dwg file into a .igs file. You have to use SketchUp Pro to export to the .dwg. When it imports into Gambit there is a lot of "noise" that comes along with it. I ensure that everything is a group before exporting. When I import into Gambit there are a lot of extra lines carried into the model and vertices that are the endpoints for the lines. I delete all the "noise" that comes along with it leaving behind my volumes that were groups in SketchUp. It is a work in process but I just recently got it to work.
heachinbar is offline   Reply With Quote
Old   May 16, 2013, 03:05
Kaptmndo
wanfuhh is on a distinguished road
Dear Tim, i would be very glad if u could show me a snapshot of the 'noise' that comes along when the files is imported and how you deleted all the 'noises'. thanks in advance.
wanfuhh is offline   Reply With Quote
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 07:28
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
Importing Gambit data into Fluent Tyred ANSYS Meshing & Geometry 1 April 18, 2009 14:53
Jobs in cfd - fluent or cfx? jobman Main CFD Forum 6 July 5, 2006 16:02
2D geometry Gambit 2.0.6 to Fluent 6 Bo Jensen FLUENT 1 January 17, 2003 10:55
