[ICEM] Volume elements dissapear
Old   November 23, 2015, 13:20
Default Volume elements disappear
Joakim
joxen is on a distinguished road
I'm trying to write a ICEM script that generates meshes fast and easily.
The 2D mesh is created by 2D-planar block and the 3D block is created by using 2D to 3D - swept command.
Sometimes when the whole script is run, by using the commands "run script", the model is generated without any volume element in a specific part.
When I use the same script run with "replay control" and uses "do one step" (and update manually in the interface) instead of using ic_hex_create_mesh, ic_hex_new, ic_hex_compute_mesh_size, all the parts are filled correctly. This problem occurs very randomly and sometimes it works to close the blocking and open it again. Does anyone have the same problem or a solution of this?
I need to run the script in batch mode so this must be solved.
Thanks for all assistance
joxen is offline   Reply With Quote
[blockMesh] edges not aligned with or perpendicular to non-empty directions ynos OpenFOAM Meshing & Mesh Conversion 6 March 26, 2020 16:02
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
975 problem volume elements were found for Uncovered faces syler3321 ANSYS Meshing & Geometry 0 October 23, 2011 04:41
help: the volume mesh has highly skewed elements xiaofish FLUENT 3 September 18, 2007 10:51
