[ANSYS Meshing] problem meshing a missile
Old   November 8, 2015, 11:48
Post problem meshing a missile
behzad jabbari
behzadjabbari68@gmail.com is on a distinguished road
Hi, I want to simulate flow over a missile importing that from solidwork to gambit.
This missile includes some volumes : main part, front wings, back wings.
I can't operate boolean operations to unite these volumes and then subtract missile from the domain to have a single volume, becasue there is virtual volume in the importing geometry from solidwork.
How can I have a single volume in spite of the fact that there are real and virtual volumes in the geometry??
behzadjabbari68@gmail.com is offline   Reply With Quote
Old   November 10, 2015, 02:17
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
As you mentionned you cannot perform boolean operations since you have virtual geometry.
Do you have the possiblity to extract fluid volume in solidworks?
What kind of format did you import in gambit?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 10, 2015, 08:35
behzad jabbari
I solved this problem .I imported the solid file in the parasolid format.Now i have one volume and want to mesh it.
What is your advise for meshing such a complex volume?
Old   November 10, 2015, 09:45
-mAx-'s Avatar
Maxime Perelli
display at least your geometry
Old   November 19, 2015, 06:32
behzad jabbari
i can't upload the image here.would you plz give me your email ? i have a real trouble meshing this complex geometry
boolean subtract, missile, volume mesh
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 18 April 19, 2023 00:49
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 08:21
Gambit meshing problem to following geometry ahmadmln ANSYS Meshing & Geometry 2 October 21, 2014 02:49
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem dalecooper ANSYS Meshing & Geometry 0 July 19, 2013 08:04
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
